To force calibration, I tried to use the code below (Adafruit SCD 30 tuning) and in fresh air, I obtain 530 ppm and
Measurement interval: 2 seconds
Ambient pressure offset: 0 mBar
Altitude offset: 300 meters
Temperature offset: 3.00 degrees C
Forced Recalibration reference: 400 ppm
Self calibration disabled
// Demo of the available settings for the SCD30
#include <Adafruit_SCD30.h>
Adafruit_SCD30 scd30;
void setup(void) {
Serial.begin(115200);
while (!Serial) delay(10); // will pause Zero, Leonardo, etc until serial console opens
Serial.println(“Adafruit SCD30 Sensor adjustment test!”);
// Try to initialize!
if (!scd30.begin()) {
Serial.println(“Failed to find SCD30 chip”);
while (1) { delay(10); }
Serial.println(“SCD30 Found!”);
- The code below will report the current settings for each of the
- settings that can be changed. To see how they work, uncomment the setting
- code above a status message and adjust the value
Note: Since Automatic self calibration and forcing recalibration with
- a reference value overwrite each other, you should only set one or the other
/*** Adjust the rate at which measurements are taken, from 2-1800 seconds */
// if (!scd30.setMeasurementInterval(5)) {
// Serial.println(“Failed to set measurement interval”);
// while(1){ delay(10);}
Serial.print(“Measurement interval: “);
Serial.print(scd30.getMeasurementInterval());
Serial.println(” seconds”);
/*** Restart continuous measurement with a pressure offset from 700 to 1400 millibar.
- Giving no argument or setting the offset to 0 will disable offset correction
// if (!scd30.startContinuousMeasurement(15)){
// Serial.println(“Failed to set ambient pressure offset”);
Serial.print(“Ambient pressure offset: “);
Serial.print(scd30.getAmbientPressureOffset());
Serial.println(” mBar”);
/*** Set an altitude offset in meters above sea level.
- Offset value stored in non-volatile memory of SCD30.
- Setting an altitude offset will override any pressure offset.
// if (!scd30.setAltitudeOffset(110)){
// Serial.println(“Failed to set altitude offset”);
Serial.print(“Altitude offset: “);
Serial.print(scd30.getAltitudeOffset());
Serial.println(” meters”);
/*** Set a temperature offset in hundredths of a degree celcius.
// if (!scd30.setTemperatureOffset(1984)){ // 19.84 degrees celcius
// Serial.println(“Failed to set temperature offset”);
Serial.print(“Temperature offset: “);
Serial.print((float)scd30.getTemperatureOffset()/100.0);
Serial.println(” degrees C”);
/*** Force the sensor to recalibrate with the given reference value
- from 400-2000 ppm. Writing a recalibration reference will overwrite
- any previous self calibration values.
- Reference value stored in non-volatile memory of SCD30.
if (!scd30.forceRecalibrationWithReference(400)){
Serial.println(“Failed to force recalibration with reference”);
while(1) { delay(10); }
Serial.print(“Forced Recalibration reference: “);
Serial.print(scd30.getForcedCalibrationReference());
Serial.println(” ppm”);
/*** Enable or disable automatic self calibration (ASC).
- Parameter stored in non-volatile memory of SCD30.
- Enabling self calibration will override any previously set
- forced calibration value.
- ASC needs continuous operation with at least 1 hour
- 400ppm CO2 concentration daily.
// if (!scd30.selfCalibrationEnabled(true)){
// Serial.println(“Failed to enable or disable self calibration”);
// while(1) { delay(10); }
if (scd30.selfCalibrationEnabled()) {
Serial.print(“Self calibration enabled”);
} else {
Serial.print(“Self calibration disabled”);
Serial.println("\n\n");
if (scd30.dataReady()) {
if (!scd30.read()){
Serial.println("Error reading sensor data");
return;
Serial.print("Temperature: ");
Serial.print(scd30.temperature);
Serial.println(" degrees C");
Serial.print("Relative Humidity: ");
Serial.print(scd30.relative_humidity);
Serial.println(" %");
Serial.print("CO2: ");
Serial.print(scd30.CO2, 3);
Serial.println(" ppm");
Serial.println("");
delay(100);
