anyone experience the build error with Himax SDK on Grove Vision AI V2?
I followed the instructions on this site:
I tried to build using the SDK which run on M1 Mac, so I got to change the toolchain to arm-gnu-toolchain-13.2.rel1-darwin-arm64-arm-none-eabi.
when build, I encounter this error:
Linking : obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/EPII_CM55M_gnu_epii_evb_WLCSP65_s.elf
/Users/wcliew/arm-gnu-toolchain-13.2.rel1-darwin-arm64-arm-none-eabi/bin/arm-none-eabi-gcc -Wl,–no-warn-rwx-segments -DALLON_SENSOR_TFLM -DARM_MATH_DSP -DARM_MATH_LOOPUNROLL -DARM_MATH_MVEI -DCM55_BIG -DCMSIS_NN -DCOREV_0P9V -DDBG_MORE -DDEBUG -DEPII_EVB -DETHOSU55 -DETHOSU_ARCH=u55 -DETHOSU_LOG_SEVERITY=ETHOSU_LOG_WARN -DETHOS_U -DEVT_DATAPATH -DHM_COMMON -DIC_PACKAGE_WLCSP65 -DIC_VERSION=30 -DIP_2x2 -DIP_5x5 -DIP_INST_ADCC -DIP_INST_ADCC_HV -DIP_INST_AON_GPIO -DIP_INST_DMA0 -DIP_INST_DMA1 -DIP_INST_DMA2 -DIP_INST_DMA3 -DIP_INST_GPIO_G0 -DIP_INST_GPIO_G1 -DIP_INST_GPIO_G2 -DIP_INST_GPIO_G3 -DIP_INST_I2S_HOST -DIP_INST_I2S_SLAVE -DIP_INST_IIC_HOST -DIP_INST_IIC_HOST_MIPI -DIP_INST_IIC_HOST_SENSOR -DIP_INST_IIIC_SLAVE0 -DIP_INST_IIIC_SLAVE1 -DIP_INST_OSPI_HOST -DIP_INST_PWM0 -DIP_INST_PWM1 -DIP_INST_PWM2 -DIP_INST_QSPI_HOST -DIP_INST_RTC0 -DIP_INST_RTC1 -DIP_INST_RTC2 -DIP_INST_SB_GPIO -DIP_INST_SSPI_HOST -DIP_INST_SSPI_SLAVE -DIP_INST_TIMER0 -DIP_INST_TIMER1 -DIP_INST_TIMER2 -DIP_INST_TIMER3 -DIP_INST_TIMER4 -DIP_INST_TIMER5 -DIP_INST_TIMER6 -DIP_INST_TIMER7 -DIP_INST_TIMER8 -DIP_INST_UART0 -DIP_INST_UART1 -DIP_INST_UART2 -DIP_INST_WDT0 -DIP_INST_WDT1 -DIP_adcc -DIP_adcc_hv -DIP_cdm -DIP_csirx -DIP_csitx -DIP_dma -DIP_dp -DIP_edm -DIP_gpio -DIP_hxautoi2c_mst -DIP_i2s -DIP_i3c_mst -DIP_i3c_slv -DIP_iic -DIP_inp -DIP_inp1bitparser -DIP_inpovparser -DIP_isp -DIP_jpeg -DIP_mb -DIP_mpc -DIP_pdm -DIP_pmu -DIP_ppc -DIP_pwm -DIP_rtc -DIP_scu -DIP_sensorctrl -DIP_spi -DIP_swreg_aon -DIP_swreg_lsc -DIP_timer -DIP_tpg -DIP_u55 -DIP_uart -DIP_vad -DIP_watchdog -DIP_xdma -DLIB_CMSIS_NN -DLIB_COMMON -DLIB_EVENT -DLIB_PWRMGMT -DLIB_QSPI_EEPROM -DLIB_SENSORDP -DLIB_SPI_EEPROM -DLIB_SPI_PTL -DSPI_EEPROM_USE_WB_25Q128JW_INST_ -DTFLM2209_U55TAG2205 -DTF_LITE_MCU_DEBUG_LOG -DTF_LITE_STATIC_MEMORY -DTRUSTZONE -DTRUSTZONE_CFG -DTRUSTZONE_SEC -DTRUSTZONE_SEC_ONLY -D__GNU__ -D__NEWLIB__ -Dseeed -L"./linker_script/" -L"./linker_script/gcc" -L"./libs" -Xlinker --gc-sections -Xlinker -print-memory-usage -Xlinker --sort-section=alignment -Xlinker --cref -mthumb -mcpu=cortex-m55 -DARMCM55 -mfloat-abi=hard -L"./linker_script/gcc/" -L"obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65" -Xlinker --cmse-implib -Wl,-M,-Map=obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/EPII_CM55M_gnu_epii_evb_WLCSP65_s.map -specs=nano.specs -T obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/EPII_CM55M_gnu_epii_evb_WLCSP65.ld @objs.in -Wl,–start-group obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/libtrustzone_cfg.a obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/libdriver.a obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/libcommon.a obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/libhxevent.a obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/libpwrmgmt.a obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/libsensordp.a obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/lib_spi_eeprom.a obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/lib_spi_ptl.a obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/lib_cmsis_nn.a obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/libextdevice.a obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/libcustomer.a obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/libtflmtag2209_u55tag2205_cmsisnn_gnu.a -lm -lc_nano -lgcc -lstdc++_nano -Wl,–end-group -o obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/EPII_CM55M_gnu_epii_evb_WLCSP65_s.elf
/Users/wcliew/arm-gnu-toolchain-13.2.Rel1-darwin-arm64-arm-none-eabi/bin/…/lib/gcc/arm-none-eabi/13.2.1/…/…/…/…/arm-none-eabi/bin/ld: cannot find @objs.in: No such file or directory
collect2: error: ld returned 1 exit status
make: *** [obj_epii_evb_icv30_bdv10/gnu_epii_evb_WLCSP65/EPII_CM55M_gnu_epii_evb_WLCSP65_s.elf] Error 1
Anyone faced the same issue?
