Ardunio & seed studio RTC
Dear Experts,
I am beginner of open hardware system.
I like to know the integrating code of ardunio (grove ardunio shield) with grove RTC timer and humidity and temperature sensor.
with my limited knowledge i have written code:
#include <SD.h>
#include “DHT.h”
#include <Wire.h>
#include “RTClib.h”
#include “DS1307.h”
#define DHTPIN A0
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
DS1307 clock; // declare object for DS3234 class
const int chipSelect = 10;
// Open serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print(“Initializing SD card…”);
// make sure that the default chip select pin is set to
// output, even if you don’t use it:
pinMode(10, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println(“Card failed, or not present”);
// don’t do anything more:
return;
Serial.println(“card initialized.”);
// create a new file
char filename[] = “LOGGER00.CSV”;
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + ‘0’;
filename[7] = i%10 + ‘0’;
if (! SD.exists(filename)) {
// only open a new file if it doesn’t exist
break; // leave the loop!
Serial.print("Logging to: ");
Serial.println(filename);
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds ‘old’ (its a very slow sensor)
float h = dht.readHumidity();
float t = dht.readTemperature();
// check if returns are valid, if they are NaN (not a number) then something went wrong!
if (isnan(t) || isnan(h))
    Serial.println("Failed to read from DHT");
else
    Serial.print("Humidity: ");
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print("Temperature: ");
    Serial.print(t);
    Serial.println(" *C");
in this case no time stamp coming with the result
only temperature and humidity displaying.
I like to display with time stamp.
can peers help me to solve in this issue ?
TIA
-sudharsan
Hi Sudharshan,
I have modified your code to include time stamp.
#include <SD.h>
#include "DHT.h"
#include <Wire.h>
#include "RTClib.h"
#include "DS1307.h"
#define DHTPIN A0
while (!Serial) {
Serial.print("Initializing SD card...");
// output, even if you don't use it:
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
char filename[] = "LOGGER00.CSV";
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
// only open a new file if it doesn't exist
//  Enter  the time and date when flashing the program
        clock.begin();
	clock.fillByYMD(2015,2,10);//Feb 10,2015
	clock.fillByHMS(15,28,30);//15:28 30"
	clock.fillDayOfWeek(TUE);//Tuesday
	clock.setTime();//write time to the RTC chip
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
//Time stamp for your program
printTime();
else
Serial.print(h);
Serial.print(t);
void printTime()
	clock.getTime();
	Serial.print(clock.hour, DEC);
	Serial.print(":");
	Serial.print(clock.minute, DEC);
	Serial.print(":");
	Serial.print(clock.second, DEC);
	Serial.print("	");
	Serial.print(clock.month, DEC);
	Serial.print("/");
	Serial.print(clock.dayOfMonth, DEC);
	Serial.print("/");
	Serial.print(clock.year+2000, DEC);
	Serial.print(" ");
	Serial.print(clock.dayOfMonth);
	Serial.print("*");
	switch (clock.dayOfWeek)// Friendly printout the weekday
		case MON:
		  Serial.print("MON");
		  break;
		case TUE:
		  Serial.print("TUE");
		  break;
		case WED:
		  Serial.print("WED");
		  break;
		case THU:
		  Serial.print("THU");
		  break;
		case FRI:
		  Serial.print("FRI");
		  break;
		case SAT:
		  Serial.print("SAT");
		  break;
		case SUN:
		  Serial.print("SUN");
		  break;
	Serial.println(" ");
If you have any other questions,just let me know.
Thank you for your reply.
your corrected code only display the data with time stamp.
The data not stored in the SD card.
can you re-modify the code to store the data into SD card ?
TIA
My hardware is working fine.
I have checked with following code for store the data in csv file it works well.
#include <SD.h>
// On the Ethernet Shield, CS is pin 4. Note that even if it’s not
// used as the CS pin, the hardware CS pin (10 on most Arduino boards,
// 53 on the Mega) must be left as an output or the SD library
// functions will not work.
while (!Serial) {
return;
// make a string for assembling the data to log:
String dataString = “”;
// read three sensors and append to the string:
for (int analogPin = 0; analogPin < 3; analogPin++) {
int sensor = analogRead(analogPin);
dataString += String(sensor);
if (analogPin < 2) {
dataString += “,”;
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open(“datalog.csv”, FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
Serial.println(dataString);
// if the file isn’t open, pop up an error:
else {
Serial.println(“error opening datalog.csv”);
