4G Sensor Hub Data Logger Connecting to AWS MQTT Broker
Good day,
I need to connect a 4G Sensor Hub to an MQTT Broker hosted by Amazon AWS IoT Core.
AWS requires all IoT devices to encrypt communications.
i) Is TLS implemented on the hub? Using the Sensor Hub Configuration Tool I do not see the option to turn TLS on/off
For testing purposes I connected the hub to the SenseCAP Portal and could see measurements being published, but I could not see anything there or in the documentation about TLS
Thanks,
Johnny
The 4G Sensor Hub handles TLS automatically, so you won’t see an option in the config tool. For AWS IoT Core, just provide the correct certificates and endpoint—the hub will manage the secure connection on its own.
