I look for info in the forum and I don’t find nothing, I need to know how connnect an arduino uno with the 4 relay shiel, I put the relay above the arduino uno and the pin connection is not correct, I need to press with my fingers to have a good contact. What I m doing wrong?
Sorry but I have a little english
Hi, what kind of press with your fingers, if there are some image, it would be better.
besides, I guess you mean this shield? : seeedstudio.com/wiki/Relay_Shield_V1.0
hello again,
I put a video on:
usuaris. tinet. org jrts IMG_1715.MOV
you can see it. I don’t know if it is a defective pins or I did it something wrong.
regards
(remove spaces and put the /)
Hi, I failed to open this video, or maybe can you put it to youtube or just send some images? ![]()
The correct adress is:
usuaris.tinet.org/jrts/IMG_1715.MOV , next time I put a photo.
get it~
look like something unstable, would you please check if the soldering is good?
or take a photo of the bottom of the shield, this may be help.
hello,
I take a bottom photo and the top.
It looks like the drills are big.
thanks
Hi, I notice that the pin of your relay shield had not been solder, you should solder it.
ok, thanks, runs well
I’ve soldered the pins, like well my firts solders, I attach an image.
[quote=“jots”]
hey, you will like solder.
there’s a funny soldering kit, maybe you’ll like it: seeedstudio.com/depot/8-SQUA … Path=34_77
cheers.
this kit is interesting for me!
thanks for all!
