Voice controlling led pixels
dusastre
Post by dusastre » Thu Jan 17, 2019 12:39 pm
hi there, I have been hired to outfit my friends RV with thousands of leds and lasers, i had been planning on using alexa to voice control between different preprogrammed light patterns, but then i remembered that alexa requires internet and this RV will predominantly be used outside of cell signal.
so i am looking for a simple and effective solution to replace alexa. i need to control a Falcon F16v3 led board
https://www.pixelcontroller.com/store/i ... er=product
i have no previous Pi experience, nor am i an experienced coder.
i started learning about home-assisstant.io, i think this can do what i need it to.
i was starting to lean towards the Snips base kit, do you think this can work? what kind of outputs/cables can it send to the falcon controller?
i like the form factor of the respeaker pro case a LOT more. can i just replace the microphone from the snips base kit with a respeaker mic array v2.0 and put that inside the pro case?
am i better off just using a respeaker core 2.0 inside the pro case? i can run the snips code on that instead? and integrate it with home-assisstant?
i hope im not asking too many dumb questions, im sorry im so new to this, i promise to learn quickly. thank you!
sfcable4seo
Contact:
Re: Voice controlling led pixels
Post by sfcable4seo » Wed Feb 20, 2019 12:04 pm
Will please explain total workflow?
