How to correctly add a USB sound module?
marc383
Post by marc383 » Mon Nov 26, 2018 11:09 am
I'm developping a special application with the Respeaker Core V2, and I need to use a multi-channel (5.1) sound module to playback surround sound (instead of stereo). The USB module works fine, but it's being registered as the first ALSA device, something that should not happen because the first ALSA device should always be the seeed-8mic-voicecard device, or else respeakerd don't work.
Is there a way to make sure than a USB sound module is always the second ALSA device?
Or is there a way to change the config of respeakerd to use the seeed-8mic-voicecard device if it's not the first ALSA device?
Thanks for your attention
bart11064
Re: How to correctly add a USB sound module?
Post by bart11064 » Fri Mar 29, 2019 11:36 pm
I have the same problem.
Did you get the solution ?
