Respeaker Core V2 network/tty* issue
Dear,
Did anyone notice the following issues after using the Respeaker Core V2 for a while:
[list]
  • []/dev/ttyACMx is not visible anymore on Ubuntu, a power cycle does not help
  • [/list]
    [list]
  • []after powering the Respeaker Core V2 it cannot be reached anymore over SSH after approximately 30 minutes, a power cycle helps
  • [/list]
    Any hint to solve this is appreciated, in particular the /dev/ttyACMx issue.
    Thanks,
    Bart
    can you share more input?
    -> How much time you are running the device?
    -> Is that happened while processing task or by doing nothing?
    -> what kind of power supply you are using?
    -> which version of firmware you are using?
