Here's a working ALSA config for dsnoop w/ mixer
Applications/questions using Raspberry Pi with Seeed products, please post it here.
Moderators: lily.li, salmanfarisvp, violet
willie
Post by willie » Sun Oct 28, 2018 8:42 am
Just wanted to share my asound.conf that works with my Respeaker 4mic with Dsnoop and it records at any sample rate.
It's set to use the Pi's onboard audio.
Code: Select all
defaults.pcm.rate_converter "samplerate"
pcm.bcm2835 {
  type hw
  card ALSA
pcm.seeed_4mic_voicecard {
  type hw
  card seeed4micvoicec
pcm.softvol {
  type softvol
  slave {
  pcm "pduplex"
  control {
  name "Master"
  card 0
pcm.!default {
  type asym
  playback.pcm "plug:softvol"
  capture.pcm "pduplex"
pcm.recmixer {
  ipc_key 140325
  ipc_key_add_uid true
  type dsnoop
  slave.pcm "seeed_4mic_voicecard"
pcm.duplex {
  type asym
  playback.pcm "bcm2835"
  capture.pcm "recmixer"
pcm.pduplex {
  type plug
  slave.pcm "duplex"
ctl.pduplex {
  type hw
  card 0
pcm.dsp0 {
  type plug
  slave.pcm "duplex"
ctl.mixer0 {
  type hw
  card 0
bill.yu
Junior-7
Junior-7
Re: Here's a working ALSA config for dsnoop w/ mixer
Post by bill.yu » Fri Nov 02, 2018 5:52 pm
Hi Willie
thanks for the sharing.
