hello
I have purchased a pi RTC that uses the two i2c pins to communicate with the pi.
The problem I have is i am using these i2c lines to communicate with another device. Is there no way both can be used on the same pins?
Hi scott.evans ,
I2C devices communicate using two wires SDA and SCL, and the identification based on address . each device have its address, so you can use many I2C devices in same SDA and SCL lines but you only need specify the address
