How to autorun a Python/Bash Script in headless mode.
Applications/questions using Raspberry Pi with Seeed products, please post it here.
Moderators: lily.li, salmanfarisvp, violet
User avatar
salmanfarisvp
Elementary-1
Elementary-1
Which products/projects are your favorite?: Linklt One , BeagleBone Green , ReSpaker
Contact:
Post by salmanfarisvp » Sat May 04, 2019 5:39 pm
I need to run a python script when Rpi is turn on, I was using a python virtual environment so I was created a script for the autorun and added on the .bashrc, but the script only starts when connecting a GUI or start new SSH session, it won't automatically start in headless mode.
Model: Raspberry Pi B
OS: Raspbian Strech
Thanks.
bash script :
Code: Select all
#!/bin/bash
source /home/pi/.profile
workon cv5
cd /home/pi/Desktop
python teste.py
Start where you are, use what you have, do what you can, Share what you know.
User avatar
salmanfarisvp
Elementary-1
Elementary-1
Contact:
Re: How to autorun a Python/Bash Script in headless mode.
Post by salmanfarisvp » Mon May 06, 2019 3:00 pm
Hi all,
found the solution, my goal is to run a python script that uses a virtual environment, so first wrote a bash script to automate the virtual environment setup then added bash script on them .bashrc
Code: Select all
#!/bin/bash
workon cv
cd /home/pi/pi-reboot
python script_name.py
but the script won't run until I open the terminal (IDK why), and my application must need to work on the headless environment, so I disabled the GUI and enabled the autologin in the terminal via
Code: Select all
raspi-config
Thank You.
