Grove - IMU 9DOF v2.0 with raspberry pi for calculating position
Moderators: lily.li, salmanfarisvp, violet
diyaela718
Post by diyaela718 » Fri Feb 07, 2020 11:25 am
I have been using Grove - IMU 9DOF v2.0 with raspberry pi to calculate the linear displacement, compass values. I followed the code given in this github url (https://github.com/FaBoPlatform/FaBo9AX ... 250-Python). While running the read9Axis.py code (which is given inside example folder) i cannot able to get magnetometer values. Can anyone help me to solve this problem??
User avatar
salmanfarisvp
Elementary-2
Elementary-2
Which products/projects are your favorite?: Linklt One , BeagleBone Green , ReSpaker
Contact:
Re: Grove - IMU 9DOF v2.0 with raspberry pi for calculating position
Post by salmanfarisvp » Fri Feb 14, 2020 1:35 am
What value is showing in the mag[x], mag[y] and mag[z] place? can you share the error?
Start where you are, use what you have, do what you can, Share what you know.
