Grove sensors // Units of measurement
nace
Post by nace » Fri Aug 24, 2018 2:31 pm
Dear all!
I would kindly ask you to provide the information about units that are used for the data sent from different sensors. We are currently using Grove Kit for Win10 IoT Core & Azure Platform https://www.seeedstudio.com/Grove-Kit-f ... -2928.html.
Grove - Temp&Humi Sensor
Temperature unit: °C
Humidity unit: (?)
Grove - Sound Sensor
Sound unit: (?)
Grove - Light Sensor v1.2
Light unit: (?)
Grove - Gas Sensor(MQ2)
Gas sensor unit: (?)
I haven't found this information while reading the documentation and other information on your website.
Thank you for your kind help and answers
bill.yu
Junior-7
Junior-7
Re: Grove sensors // Units of measurement
Post by bill.yu » Fri Aug 24, 2018 4:19 pm
Hi Nace,
Humidity unit: Relative Humidity, %
Sound unit: if you use 10bit adc and 5v voltage, just map the 5v voltage to 1023. there is no unit.
Light unit: if you use 10bit adc and 5v voltage, just map the 5v voltage to 1023. there is no unit.
Gas sensor unit: if you use 10bit adc and 5v voltage, just map the 5v voltage to 1023. there is no unit.
thanks
Bill
nace
Post by nace » Mon Aug 27, 2018 2:25 pm
Dear Bill!
Thank you for your kind explanation.
