Grove GPS with Grove Base Hat for Raspberry Pi (Changing port definitions?)
Moderators: lily.li, violet, salmanfarisvp, jeremy882, crail.lyu969
melvinlee18
Post by melvinlee18 » Fri Nov 01, 2019 3:12 am
Hi people,
Is it possible to connect the Grove GPS with Grove Base Hat for Raspberry Pi?
I just realized there is no RPISER port on the Grove Base Hat.
bill.yu
Junior-7
Junior-7
Re: Grove GPS with Grove Base Hat for Raspberry Pi
Post by bill.yu » Fri Nov 01, 2019 5:51 pm
Hi there~
It's compatible but you need to modify source code to change the port.
melvinlee18
Post by melvinlee18 » Fri Nov 01, 2019 6:09 pm
That's great!
Do I connect the GPS to the UART port of the Grove Base Hat?
melvinlee18
Post by melvinlee18 » Mon Nov 04, 2019 1:16 am
Hi guys,
how do I change the port to the UART port or a Digital port?
code from desterGPS.py:
lass GROVEGPS():
def __init__(self, port='/dev/ttyAMA0', baud=9600, timeout=0):
self.ser = serial.Serial(port, baud, timeout=timeout)
self.ser.flush()
self.raw_line = ""
self.gga = []
self.validation =[] # contains compiled regex
