Is the Grove - IR Distance Interrupter supported in the seeedstudio grove.py library? if so… does anyone have sample?
<LINK_TEXT text=“https://www.seeedstudio.com/Grove-IR-Di … -1278.html”>https://www.seeedstudio.com/Grove-IR-Distance-Interrupter-p-1278.html</LINK_TEXT>
Hi There
</s><i>
</i>import time
from grove.gpio import GPIO
IR_Distance = GPIO(22, GPIO.IN)
while True:
if IR_Distance.read():
print "found something"
else:
print "nothing"
time.sleep(0.1)
<e>
Thank you for your response. In the grove hat for pi zero the PIN 22 would be the PWM slot?
Hi There
it is not likely to be a hardware PWM , but it can use software PWM by visit <LINK_TEXT text=“https://www.raspberrypi.org/forums/view … p?t=183770”>https://www.raspberrypi.org/forums/viewtopic.php?t=183770</LINK_TEXT>
