Grove IMU 10DOF interrupt mode
hmarois21
Post by hmarois21 » Sat Feb 09, 2019 11:03 pm
Hello
In order to use the mpu9250 in fifo mode, (for dmp usage)
I need to have an interrrupt
I've used the #define INTERRUPT_PIN 2 // use pin 2 on Arduino Uno & most boards
But it doesnt work
User avatar
bestlux
Kindergarten
Kindergarten
Re: Grove IMU 10DOF interrupt mode
Post by bestlux » Mon Feb 18, 2019 2:40 pm
please look at Pad2 that marked on the graph, it does not connect to any pin. And you need to solder a pin or line on it and connect it to the pin you select in your code.
