I have experienced compiling error when trying my recent purchased board. At the moment I am not connected to the board, I am just trying to compile the examples included .
I have found the “platform.txt” file and tried changing lines 75 and 76 both ways using the analog and button examples with no sucess.
Can you help?
Thanks Mitch
I get the following :
Arduino: 1.8.8 (Mac OS X), TD: 1.45, Board: “Seeeduino Wio lite MG126”
/Applications/Arduino1-8-8.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino1-8-8.app/Contents/Java/hardware -hardware /Users/mitchstipp/Library/Arduino15/packages -tools /Applications/Arduino1-8-8.app/Contents/Java/tools-builder -tools /Applications/Arduino1-8-8.app/Contents/Java/hardware/tools/avr -tools /Users/mitchstipp/Library/Arduino15/packages -built-in-libraries /Applications/Arduino1-8-8.app/Contents/Java/libraries -libraries /Users/mitchstipp/Documents/Arduino/libraries -fqbn=Seeeduino:Seeeduino_Wio_Lite_MG126:Wio_Lite_MG126 -ide-version=10808 -build-path /var/folders/9g/ts2qc5r56hb6gtg9hg5l4zl40000gn/T/arduino_build_995792 -warnings=none -build-cache /var/folders/9g/ts2qc5r56hb6gtg9hg5l4zl40000gn/T/arduino_cache_587569 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/4.8.3-2014q1 -prefs=runtime.tools.CMSIS-Atmel.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.1.0 -prefs=runtime.tools.CMSIS-Atmel-1.1.0.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.1.0 -prefs=runtime.tools.arduinoOTA.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arduinoOTA/1.2.0 -prefs=runtime.tools.arduinoOTA-1.2.0.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arduinoOTA/1.2.0 -prefs=runtime.tools.bossac.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/bossac/1.7.0 -prefs=runtime.tools.bossac-1.7.0.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/bossac/1.7.0 -prefs=runtime.tools.openocd.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/openocd/0.9.0-arduino6-static -prefs=runtime.tools.openocd-0.9.0-arduino6-static.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/openocd/0.9.0-arduino6-static -prefs=runtime.tools.CMSIS.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS/4.5.0 -verbose /var/folders/9g/ts2qc5r56hb6gtg9hg5l4zl40000gn/T/arduino_modified_sketch_114586/echo_ble.ino
/Applications/Arduino1-8-8.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino1-8-8.app/Contents/Java/hardware -hardware /Users/mitchstipp/Library/Arduino15/packages -tools /Applications/Arduino1-8-8.app/Contents/Java/tools-builder -tools /Applications/Arduino1-8-8.app/Contents/Java/hardware/tools/avr -tools /Users/mitchstipp/Library/Arduino15/packages -built-in-libraries /Applications/Arduino1-8-8.app/Contents/Java/libraries -libraries /Users/mitchstipp/Documents/Arduino/libraries -fqbn=Seeeduino:Seeeduino_Wio_Lite_MG126:Wio_Lite_MG126 -ide-version=10808 -build-path /var/folders/9g/ts2qc5r56hb6gtg9hg5l4zl40000gn/T/arduino_build_995792 -warnings=none -build-cache /var/folders/9g/ts2qc5r56hb6gtg9hg5l4zl40000gn/T/arduino_cache_587569 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/4.8.3-2014q1 -prefs=runtime.tools.CMSIS-Atmel.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.1.0 -prefs=runtime.tools.CMSIS-Atmel-1.1.0.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.1.0 -prefs=runtime.tools.arduinoOTA.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arduinoOTA/1.2.0 -prefs=runtime.tools.arduinoOTA-1.2.0.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arduinoOTA/1.2.0 -prefs=runtime.tools.bossac.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/bossac/1.7.0 -prefs=runtime.tools.bossac-1.7.0.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/bossac/1.7.0 -prefs=runtime.tools.openocd.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/openocd/0.9.0-arduino6-static -prefs=runtime.tools.openocd-0.9.0-arduino6-static.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/openocd/0.9.0-arduino6-static -prefs=runtime.tools.CMSIS.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS/4.5.0 -verbose /var/folders/9g/ts2qc5r56hb6gtg9hg5l4zl40000gn/T/arduino_modified_sketch_114586/echo_ble.ino
Using board ‘Wio_Lite_MG126’ from platform in folder: /Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0
Using core ‘arduino’ from platform in folder: /Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0
Detecting libraries used…
/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-inns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DARDUINO_ARCH_SAMD -DF_CPU=48000000L -DARDUINO=10808 -DARDUINO_Wio_Lite_MG126 -DARDUINO_ARCH_SEEEDUINO_WIO_LITE_MG126 -D SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2886 -DUSB_PID=0x802A -DUSBCON “-DUSB_MANUFACTURER=“Unknown”” "-DUSB_PRODUCT=“Seeeduino_Wio_Lite_MG126"” -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/cores/arduino -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/variants/Wio_Lite_MG126 /var/folders/9g/ts2qc5r56hb6gtg9hg5l4zl40000gn/T/arduino_build_995792/sketch/echo_ble.ino.cpp -o /dev/null
/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-inns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DARDUINO_ARCH_SAMD -DF_CPU=48000000L -DARDUINO=10808 -DARDUINO_Wio_Lite_MG126 -DARDUINO_ARCH_SEEEDUINO_WIO_LITE_MG126 -D SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2886 -DUSB_PID=0x802A -DUSBCON “-DUSB_MANUFACTURER=“Unknown”” "-DUSB_PRODUCT=“Seeeduino_Wio_Lite_MG126"” -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/cores/arduino -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/variants/Wio_Lite_MG126 -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/wio_lite_ble_demo/src /var/folders/9g/ts2qc5r56hb6gtg9hg5l4zl40000gn/T/arduino_build_995792/sketch/echo_ble.ino.cpp -o /dev/null
/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-inns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DARDUINO_ARCH_SAMD -DF_CPU=48000000L -DARDUINO=10808 -DARDUINO_Wio_Lite_MG126 -DARDUINO_ARCH_SEEEDUINO_WIO_LITE_MG126 -D SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2886 -DUSB_PID=0x802A -DUSBCON “-DUSB_MANUFACTURER=“Unknown”” "-DUSB_PRODUCT=“Seeeduino_Wio_Lite_MG126"” -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/cores/arduino -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/variants/Wio_Lite_MG126 -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/wio_lite_ble_demo/src -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/SPI /var/folders/9g/ts2qc5r56hb6gtg9hg5l4zl40000gn/T/arduino_build_995792/sketch/echo_ble.ino.cpp -o /dev/null
Using cached library dependencies for file: /var/folders/9g/ts2qc5r56hb6gtg9hg5l4zl40000gn/T/arduino_build_995792/sketch/app_hogp.c
/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-inns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DARDUINO_ARCH_SAMD -DF_CPU=48000000L -DARDUINO=10808 -DARDUINO_Wio_Lite_MG126 -DARDUINO_ARCH_SEEEDUINO_WIO_LITE_MG126 -D SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2886 -DUSB_PID=0x802A -DUSBCON “-DUSB_MANUFACTURER=“Unknown”” "-DUSB_PRODUCT=“Seeeduino_Wio_Lite_MG126"” -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/cores/arduino -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/variants/Wio_Lite_MG126 -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/wio_lite_ble_demo/src -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/SPI /Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/wio_lite_ble_demo/src/MG126_Ble.cpp -o /dev/null
/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-inns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DARDUINO_ARCH_SAMD -DF_CPU=48000000L -DARDUINO=10808 -DARDUINO_Wio_Lite_MG126 -DARDUINO_ARCH_SEEEDUINO_WIO_LITE_MG126 -D SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2886 -DUSB_PID=0x802A -DUSBCON “-DUSB_MANUFACTURER=“Unknown”” "-DUSB_PRODUCT=“Seeeduino_Wio_Lite_MG126"” -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/cores/arduino -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/variants/Wio_Lite_MG126 -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/wio_lite_ble_demo/src -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/SPI /Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/wio_lite_ble_demo/src/bsp.c -o /dev/null
/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-inns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DARDUINO_ARCH_SAMD -DF_CPU=48000000L -DARDUINO=10808 -DARDUINO_Wio_Lite_MG126 -DARDUINO_ARCH_SEEEDUINO_WIO_LITE_MG126 -D SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2886 -DUSB_PID=0x802A -DUSBCON “-DUSB_MANUFACTURER=“Unknown”” "-DUSB_PRODUCT=“Seeeduino_Wio_Lite_MG126"” -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/cores/arduino -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/variants/Wio_Lite_MG126 -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/wio_lite_ble_demo/src -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/SPI /Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/wio_lite_ble_demo/src/spi_wrapper.cpp -o /dev/null
/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-inns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DARDUINO_ARCH_SAMD -DF_CPU=48000000L -DARDUINO=10808 -DARDUINO_Wio_Lite_MG126 -DARDUINO_ARCH_SEEEDUINO_WIO_LITE_MG126 -D SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2886 -DUSB_PID=0x802A -DUSBCON “-DUSB_MANUFACTURER=“Unknown”” "-DUSB_PRODUCT=“Seeeduino_Wio_Lite_MG126"” -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/cores/arduino -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/variants/Wio_Lite_MG126 -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/wio_lite_ble_demo/src -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/SPI /Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/SPI/SPI.cpp -o /dev/null
WARNING: library SPI claims to run on (samd) architecture(s) and may be incompatible with your current board which runs on (Seeeduino_Wio_Lite_MG126) architecture(s).
Generating function prototypes…
/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-inns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DARDUINO_ARCH_SAMD -DF_CPU=48000000L -DARDUINO=10808 -DARDUINO_Wio_Lite_MG126 -DARDUINO_ARCH_SEEEDUINO_WIO_LITE_MG126 -D SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2886 -DUSB_PID=0x802A -DUSBCON “-DUSB_MANUFACTURER=“Unknown”” "-DUSB_PRODUCT=“Seeeduino_Wio_Lite_MG126"” -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/cores/arduino -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/variants/Wio_Lite_MG126 -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/wio_lite_ble_demo/src -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/SPI /var/folders/9g/ts2qc5r56hb6gtg9hg5l4zl40000gn/T/arduino_build_995792/sketch/echo_ble.ino.cpp -o /var/folders/9g/ts2qc5r56hb6gtg9hg5l4zl40000gn/T/arduino_build_995792/preproc/ctags_target_for_gcc_minus_e.cpp
/Applications/Arduino1-8-8.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c+±kinds=svpf --fields=KSTtzns --line-directives /var/folders/9g/ts2qc5r56hb6gtg9hg5l4zl40000gn/T/arduino_build_995792/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch…
Using previously compiled file: /var/folders/9g/ts2qc5r56hb6gtg9hg5l4zl40000gn/T/arduino_build_995792/sketch/app_hogp.c.o
/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-inns-single=500 -fno-rtti -fno-exceptions -MMD -DARDUINO_ARCH_SAMD -DF_CPU=48000000L -DARDUINO=10808 -DARDUINO_Wio_Lite_MG126 -DARDUINO_ARCH_SEEEDUINO_WIO_LITE_MG126 -D SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2886 -DUSB_PID=0x802A -DUSBCON “-DUSB_MANUFACTURER=“Unknown”” "-DUSB_PRODUCT=“Seeeduino_Wio_Lite_MG126"” -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/ -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/cores/arduino -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/variants/Wio_Lite_MG126 -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/wio_lite_ble_demo/src -I/Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/SPI /var/folders/9g/ts2qc5r56hb6gtg9hg5l4zl40000gn/T/arduino_build_995792/sketch/echo_ble.ino.cpp -o /var/folders/9g/ts2qc5r56hb6gtg9hg5l4zl40000gn/T/arduino_build_995792/sketch/echo_ble.ino.cpp.o
cc1plus: error: invalid parameter ‘max-inline-inns-single’
Using library wio_lite_ble_demo at version 1.0.0 in folder: /Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/wio_lite_ble_demo
Using library SPI at version 1.0 in folder: /Users/mitchstipp/Library/Arduino15/packages/Seeeduino/hardware/Seeeduino_Wio_Lite_MG126/1.0.0/libraries/SPI
exit status 1
Error compiling for board Seeeduino Wio lite MG126.
Hi There
I would be sorry that have’t MAC computer at present . :oops: But I am successful when i use windows to compile demo that you said
So , maybe you can try using windows to compile demo that you said
