Xiao ESP32C3 KiCad library missing battery pads
Hi! I grabbed the KiCad library for this board at the bottom of the page here: Getting Started | Seeed Studio Wiki
The symbol and footprint loaded fine, but they’re missing the battery and jtag pads. The battery pads are what’s most important to me, as the whole reason I brought this into KiCad was to design a board that interfaces with them so it can expose a connector for a LiPo battery.
Has anyone produced their own files, or is there something better available? Or maybe I’ve missed something.
i just discovered the same, and was planning to design a motherboard pcb … :face_with_diagonal_mouth:
Hello!
You can import the .dxf file of this bat solder pad into the PCB design software and place it in the appropriate position.
XIAO ESP32C3-bat.zip (51.8 KB)
(The.dxf file is in the compressed package, please check)
What about battery pad in the schematic? Also why isn’t the footprint already having the battery pads in the correct position
Did anyone find a solution to this one? I’ve hit the same issue with a esp32s3 no battery pads in the schematic Symbol. Cheers
Hello !
Don’t know if this helps, but the SMD footprint version has the battery Pad.
On the other hand, does anyone found an easy solution ? (ie: importing directly a good footprint library ?)
Regards,
FB
