So here you can USE a Xiao ESP32C3 and the single channel relay board once connected and programmed After it boots up the “boot” button can be used to turn ON/Off the relay.
// Define the pins
const int BOOT_BUTTON_PIN = 9; // Boot button; for Xiao ESP32C3 adjust if your board uses a different pin
const int LED_PIN = 3; // LED connected to R1
bool ledState = false; // current state of the LED
bool lastButtonState = HIGH; // to track button state for detecting edges
Serial.begin(115200);
while (!Serial) {
; // Wait for Serial connection (if needed)
Serial.println("Boot Button LED Toggle Example");
// Configure the boot button pin as input with internal pull-up.
pinMode(BOOT_BUTTON_PIN, INPUT_PULLUP);
// Configure the LED pin as an output.
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, LOW); // Start with LED off (assuming LED turns on when HIGH; adjust if reversed)
void loop() {
// Read the state of the boot button (active low)
bool currentButtonState = digitalRead(BOOT_BUTTON_PIN);
// Check for a button press: transition from HIGH to LOW.
if (currentButtonState == LOW && lastButtonState == HIGH) {
// Toggle the LED state
ledState = !ledState;
digitalWrite(LED_PIN, ledState ? HIGH : LOW);
Serial.print("LED toggled: ");
Serial.println(ledState ? "ON" : "OFF");
// Simple debounce delay
delay(50);
// Save the current state for the next loop iteration
lastButtonState = currentButtonState;
// Small delay to avoid rapid polling
delay(10);
Works, Great!
GL PJ
