I was able to follow the Seed instructions for the cam and get the web server working I wanted to try the instruction “Taking photos with the camera”
I ran into a problem trying to install the dependencies from github that are need to complete the sketch… could you shed some light on that? I thought it was like adding a zip librarypage picture but I was wrong
It is more than likely it is the BSP version. If it is the current one and therefor not compiling ? is that he case? Some of those examples/Demo’s only work with the older Board Support packages.
Rollback to the older one and try again.
Unload any other stuff you have that’s not required, keep it lean make sure to enable the PSram and tools etc.
GL
PJ ![]()
Cool Thanks I’ll try
