Xiao BLE Sense SD Audio,
Hello, I would like to know how I can record audio on an SD card, I suppose there will be a buffer limitation to record.
Let’s see if anyone can guide me.
Thank you
In this tutorial:
I can’t initialize SD, why?
serial message: initialization failed!
I use slot SD, what is CS in this sketch?
Thank you.
I got it, you had to declare the pin and put it in the SD BEGIN
const int chipSelect = 4;
Can you upload the full code which you have used. I tried but got an error as initialization failed. It will be really helpful if you could mention which sd card module you have used and the connections.
Thank you
Hello, can you share the full code? I’m struggling with same error. Thanks
