Wio terminal. How to generate a .UF2 to drag-n-drop to a second Wio terminal?
Same as topic. I hope someone can tell me whether Wio terminal supports drag-n-drop .UF2 firmware upload and how to generate a .UF2 file. I want to flash a second Wio terminal by drag-n-drop instead of going through Arduino IDE again. I want to send firmware to someone else without having to have them install all the libraries etc. Thanks.
Here is what I find and the boards don’t include Wio terminal:
So is there any way to have a tool that generates .UF2 for Wio terminal? I know it should be doable because this official tutorial has it:
Hi @zliudr ,
I know two ways.
  1. Copy from Arduino drive of the first Wio Terminal. (CURRENT.UF2 file)
  2. Use my UF2 converter site. ( uf2 )
FYI
https://lab.seeed.co.jp/entry/2021/03/29/120000
Hi Thanks @matsujirushi I didn’t know you could just copy and paste that CURRENT.UF2 but I’ll definitely check out your converter as well.
I can’t believe it was this easy. Thanks again @matsujirushi!
