I am trying to burn the latest Ardupy Firmware to Wio Terminal. I follow the instructions perfectly. But at the end of the process there is NO Ardupy drive on my PC.
Please help?
Sincerely,
soky
Please help?
Sincerely,
soky
Did you connect your Wio Terminal to your PC properly? Check the port appeared in your PC first before connecting.
Also you can enter the bootloader mode first to flash Ardupy。
Yes, I did both correctly several times.
Also yes I can enter the Bootloader mode
Does flashing under the bootloader mode work for you?
Hi again, I am not sure how to flash under the bootloader mode
Simply slide the power switch twice. An Arduino USB drive will appear and so does a COM should appear. Then do aip flash on the terminal to flash.
