Windows freezes when i try to access xiao
hello, I just got few xiao boards, and first i tried to upload simple sketch with arduino ide, it wasn’t working. I am getting error while uploading it:
Set binary mode
No device found on COM8
An error occurred while uploading the sketch
then i wanted to try to use circuit python. When i connect board to pc, quickly double short rst pins, i get “Arduino” window opened, but when i try to paste or drag an drop uf2 file windows freezes.
my pc is windows 10 64bit, i tried multiple usb ports
Hi Aleksandar,
Have you selected the correct COM port which relates to the Seeeduino XIAO that is connected?
In Arduino IDE, under Tools > Port
Let me know how it goes.
Regards,
Lakshantha
Hi Lakshantha, thanks for helping, but the problem was solved by restarting my PC :man_facepalming: now it works like a charm :slight_smile:
Installed memory that is not sufficient and paired with a CPU with greater processing capacity may cause the Windows to freeze. If no malware or corrupted files are found, and resetting the computer does not resolve the problem, increasing or upgrading RAM may solve the problem.
Hope You Find This Useful,
Peter
