I’ve loaded Python 3. Started to load the “python-periphery” but noticed it is for Linux, not windows. Is there a similar WiKi that talks about using the windows 10 load that comes with the board to access GPIO?
Sorry, it’s not supported on Windows, but you can use Arduino for real-time control. @jwschull
@Baozhu
Did not realize this before I ordered.
Can Windows IOT Enterprise version access the GPIO pins?
I see the AAEON UP boards have a Framework that you can install to access the GPIO’s.
Are there any plans to release a similar Framework for the Odyssey?
Also seems that the RHPROXY is a option but bios has to support it?
Hi Jag,
May I know what market or application you plan to use GPIO on Window-10?
Probably home automation. Specifically, Temp, Humidity, Radon and COx gas mitigation. And yes, I know that the arduino subsystem can do that.
