Wifi shield (SKU:WLS06201P) can work with Arduino Due. On hardware, you can connect them via one of the four Serial Ports on Arduino Due(If you use Serial 1-3, you may need to make the connection with jumper wires). The current wifi shield library uses SoftwareSerial, you should modify it to Serial port of Arduino Due.
Thanks.
