Wifi Sheild
i want to ask, when i verify the TCP code, there have problem at WiflyClass…
‘WiflyClass does not name a type’
why this happen? i just want to plug in the wifi sheild to arduino leonardo
Hi,maybe you have put your libraries in a wrong path,please check it:
…arduino\libraries\WifiShield\example\TCP\TCP.INO
Now wifi shield is not compatible with Leonardo,maybe you can use it after modified the code.
which arduino that compatible with this wifi sheild?
hi,Arduno UNO and Seeeduino R3 are both ok. And if you are interested in software,maybe you can have a try to use Leonardo.
And we will take your opinion into consideration,our products would be able compatible with many boards in the future.
