Today I have a problem about the WIO Terminal bought the last month.
As requested by the website SEEED, I updated the Realtek RTL8720’s software. Everything was working well. So, I tested the following example : “Server connect to Client of Smartphone”. Since, I was able to develop many graphic applications.
Yesterday, I tried to develop a bluetooth application but, the WIO Terminal was no longer responding. I saw an new version of the Realtek RTL8720 ( https://github.com/Seeed-Studio/seeed-ambd-firmware/releases/download/v2.1.2/20210317-seeed-ambd-firmware-rpc-v2.1.2.zip ) and I did it.
After installing the above firmware, The process was installed correctly, I tried to read the version with “the Check RTL8720 Firmware Version from Arduino IDE” , but, I had the same issue, the Terminal is still no longer responding. The others terminal fonctions still working. I think so, it the problem is linked to the radio module.
What do you think about it ? Do you have some advices ? Do you know if someone has the same problem?
Thanks for your support !
