Unable to flash Respeaker Lite firmware!
Hi
Following the Wiki instruction I try to update the flash program of the respeaker lite itself (not the ESP) but it doesn’t work.
dfu-util sees the device but can’t access it. I have rebooted after doing the modifications indicated by wiki for usb access in linux !
vincen@fixe:~/Bureau$ dfu-util -e -a 1 -D ffva_ua_v2.0.5.bin
dfu-util 0.11
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2021 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
dfu-util: Warning: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release
dfu-util: Cannot open DFU device 2886:0019 found on devnum 4 (LIBUSB_ERROR_ACCESS)
dfu-util: No DFU capable USB device available
vincen@fixe:~/Bureau$ lsusb
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 002: ID 174c:3074 ASMedia Technology Inc. ASM1074 SuperSpeed hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 006: ID 0bda:58b0 Realtek Semiconductor Corp. FULL HD 1080P Webcam
Bus 005 Device 005: ID 1e54:2030 TypeMatrix 2030 USB Keyboard
Bus 005 Device 004: ID 046d:c077 Logitech, Inc. Mouse
Bus 005 Device 003: ID 051d:0002 American Power Conversion Uninterruptible Power Supply
Bus 005 Device 002: ID 174c:2074 ASMedia Technology Inc. ASM1074 High-Speed hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 2109:0822 VIA Labs, Inc. USB3.1 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 010: ID 05e3:0723 Genesys Logic, Inc. GL827L SD/MMC/MS Flash Card Reader
Bus 001 Device 008: ID 058f:6362 Alcor Micro Corp. Flash Card Reader/Writer
Bus 001 Device 006: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 005: ID 0b05:19af ASUSTek Computer, Inc. AURA LED Controller
Bus 001 Device 003: ID 0b05:1a52 ASUSTek Computer, Inc. USB Audio
Bus 001 Device 004: ID 2886:0019 Seeed Technology Co., Ltd. ReSpeaker 2 Mics Array
Bus 001 Device 002: ID 2109:2822 VIA Labs, Inc. USB2.0 Hub
Bus 001 Device 009: ID 19b5:0004 B & W Group MM-1
Bus 001 Device 007: ID 0489:e0e2 Foxconn / Hon Hai Wireless_Device
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Side note: the board doesn’t show up as audio interface in Linux although it should according at documentation.
Vincèn
Hello Vincèn, looks like something related to permissions, can you try sudo dfu-util -e -a 1 -D ffva_ua_v2.0.5.bin?
Hi @Jessie1_SenseCAP
Thanks a lot and didn’t think it would need root rights, now it’s all good :ok_hand: I have submitted a modification at wiki to correct the Linux part of it :wink:
Also why do you offer a version 1.0.5 and 2.0.5 of respeaker lite fw in Wiki ?
Vincèn
Hi Vincèn,
ffva_ua_v2.0.5 is the firmware for USB usage, and ffva_i2s_v1.0.5 is for I2S usage(used with XIAO-ESP32S3, QT Py…)
Thanks @Jessie1_SenseCAP for explanations :ok_hand:
