Tutorial: Perform a CURD action using CC3200 LaunchPad
Iot Device always need the internet capabilities. So they can Get/Post some sensor data to/from a web server.
The simple step-by-step tutorial for IOT developers to getting up and running with Low-Energy WiFi device and rest api.
Making you connected things talk to your cloud in 30 minutes.
Here’s the deal: I’m going to show you how to get all of this stuff set up. I’ll be assuming that you’re a full-stack programmer who knows JavaScript/Node.JS/Express/Arduino well enough that I don’t have to explain those. If that’s you, then this should be a solid primer.
Let’s go.
Part1: Writing the Server side code:
var http = require('http');
var express = require('express');
var mongoose = require('mongoose');
var app = express();
app.use(express.logger());
app.use(express.bodyParser());
function getTimes(req, res) {
    var now = new Date();
    var hour = now.getUTCHours();
    var minites = now.getUTCMinutes();
    var strHour = hour.toString();
    var strMinites = minites.toString();
    return res.json({ hour: strHour, minites: strMinites });
app.get('/v1/times', getTimes);
In restful design, all of the resource can be described by URL.
here, we route URL /v1/times to method “getTimes()”
Every time CC3200 Get URL /v1/times, the method will be called.
and a json string will be returned.
Part2: Device side, CC3200 + Energia
Much like Arduino + WiFi shield. But more powerful.
[code]/** perform a Curd to web resource
@param serverIp IP address of the server to connect to
@param serverName Name of the server being connected to. If NULL, the
“Host” header line won’t be sent
@param urlPath Url to request
@param httpMethod CURD http method
@return response body in json string format
String PerformHttpCurd(int httpMethod, const char
urlPath, const IPAddress &serverIp, const char* serverName, const int serverPort) {
String strJson = “”;
int err = 0;
if(httpMethod == GET) {
err = http.get(serverIp, serverName, serverPort , urlPath);
} else if(httpMethod == POST) {
err = http.post(serverIp, serverName, serverPort , urlPath);
} else if(httpMethod == PUT) {
err = http.put(serverIp, serverName, serverPort , urlPath);
} else if(httpMethod == DELETE) {
return “”; //delete is not supported now
} else {
return “”;
if(0 == err) {
    Serial.println(F("StartedRequest OK"));
	err = http.responseStatusCode();
	if(err >= 0) {
	    Serial.print("Got status code: ");
		Serial.println(err);
		err = http.skipResponseHeaders();
		if(err >= 0) {
		    int bodyLen = http.contentLength();
			Serial.print("Body len:");
			Serial.println(bodyLen);
			//implement a timeout approach
			uint32_t timeoutStart = millis();
            while((http.connected() || http.available()) && ((millis() - timeoutStart) < kNetworkTimeout)) {
			    if(http.available()) {
				    char c = http.read();
					strJson += c;
					timeoutStart = millis();    //we read something, reset the timeout
				} else {
				    delay(kNetworkDelay);       //wait for any response
		} else {
		    Serial.print(F("Fail to skip the response header: "));
	} else {
	    Serial.print(F("Get response failed: "));
} else {
    Serial.print(F("Connected fail: "));
http.stop();           //release web service
return strJson;        //return the http body in json string format
// #end region Call web service [/code]
Gateway program will read its configuration files at startup. We create a yaml file in root directory. Modify the following items to meet your request.
Our excellent online ccna training programs will lead you to success in the ccna exam questions We also offer latest ccna service provider and Rasmussen College with 100% success guarantee. Our Sterling College is rare in IT world.
Tutorial curd is very nice…
Great! For software testing, a thorough grasp of systems is essential. Item testing designs must evolve in tandem with programming organization designs. For a lengthy period of time, sticking to a single method of surveying the thing will not work. Continue to read- Software Testing Training in Nashik
