The STEP file at https://www.seeedstudio.com/catalog/product/view/id/5975/#review-form could not be imported into OnShape correctly.
- The conversion process reported topology errors
- The base is integrated with the bottom plate and even after separating the bottom plate the structure persists with the base
Is it possible for someone to investigate this issue and to release a revised STEP file that can be imported into OnShape without topology error(s)? Thanks.
Regards.
P.S.
I can separate the file into three major STL files but the base always has the bottom plate which I cannot remove in OnShape (my knowledge of OnShape is very limited).
