Dear all,
I have been trying to use ugui library (used in RePhone Kit default application) with Arduino. First thing I need is a function that draws a point, so I wrapped method Lcd.draw_point from library LDisplay, but it doesn’t work.
After some research I discovered that drawing code in LDisplay/utility/Display.cpp
boolean lcd_draw_point(void* user_data)
    point_info_struct* data = (point_info_struct*) user_data;
    //vm_graphic_point_t frame_position[1] = {0, 0};
    vm_graphic_color_argb_t color;
    color.a = 0;
    color.r = ((data->PCulValue >> 16) & 0xff);
    color.g = ((data->PCulValue >> 8) & 0xff);
    color.b = (data->PCulValue & 0xff);
    vm_graphic_set_color(color);
    vm_graphic_draw_point(&g_frame, data->ulX, data->ulY);
    VMUINT16 *pbuf = (VMUINT16 *)g_frame.buffer;
    pbuf += data->ulY * 240 + data->ulX;
    *pbuf = ((data->PCulValue >> 8) & (0x1F << 11)) | ((data->PCulValue >> 5) & (0x3F << 5)) | ((data->PCulValue >> 3) & 0x1F);
    vm_graphic_rotate_frame(&g_rotated_frame, &g_frame, VM_GRAPHIC_ROTATE_180);
    //vm_graphic_blt_frame(g_frame_blt_group, frame_position, (VMINT)1);
    return true;
}I uncommented the central part and commented lines with “pbuf”, that I don’t now what they do, and now it works (warning: a call to Lcd.draw_updata() is needed after drawing points):
    color.a = 0;
    return true;
}Is it a real bug or I have missed something?
Best regards.
 asf.dominio:
Dear all,
    color.a = 0;
    return true;
    color.a = 0;
    return true;
Best regards.
Hi, please check my image below. Actually the commented part and the uncommented part, they both work drawing points on the LCD, but we do recommend you using the uncommented phrases as we do cause they works much faster, also if you do so, you need to use the function “lcd_draw_updata(void* user_data)
