Spectrum Analysis, Bandwidth and Resolution questions
Is it possible to do a spectrum analysis on the stored data ? My application for which I am considering DSO Nano is that I would like to analyse high frequency noise and oscillations on power supply rails and output of audio amplifiers. Will I be able to do this using DSO Nano ? The way I intend to do this is capture(store) the measured data, export it out to a pc/laptop and then use a spectrum analysis tool (like RMAA, ARTA etc…) to analyse the spectrum.
Also, can you anyone please clear one more thing for me - I am not quite clear about the bandwidth and resolution of the original Nano which is no longer available versus the new Nano v2. Is it 1Mhz or 200Khz ? and is the resolution 12bit or 8bit ? I’d appreciate if someone can kindly help me out in this matter.
Thanks!
seriously ? no one knows ?
seeedstudio.com/wiki/DSO_Nano_v2
Thanks.
So why was the analog bandwidth dropped to 200Khz in v2 from the original’s 1Mhz ?
The ones who wrote it mixed up sample rate with analog bandwidth.
ok, so analog bandwidth of v2 spec (200khz) is the correct one, right ?
Exactly. The same applies to the v1.
