Solution for Arduino Uploading error
If you are having trouble uploading a sketch to your Seeed studio Mega then:
In the Arduino IDE, under tools, check for proper serial port and board type.
If you still have problems uploading, wiggle the RST switch on the board and leave it in the ‘A’ position. Then try loading a sketch again. Some times the switch does not make good contact and this can cause loading errors.
