SHT35 Sensor - Pull up resistor required?
I want to use two SHT35 humidity sensor with a Raspberry Pi. When taking a look at the data sheet from seed, it seems like there are already 10k resistors between SDA, SCL and VCC integrated on the PCB board. Do I still need to use pull up resistors on the wiring?
Cheers,
