Hello, i’m a french young and passionate boy and i have recently received your shield bluetooth but, and as i have noticed, other person also had the same problem, I can not seem to make it work !
I explain my problem, I D1 LED blinking 2 times per second but never red LED turn on that will have signified the activity of this module !
I tested many different code from the officiel wiki, master and slave but i have always a green LED blinking…
But I have done a lot of research on this subject, I found a lot of anything and I tried all is but not all functioned ever !
My plugs are correctly, I tried to disconnect / reconnect the card, reset, remove / restore module etc.
I posted on two french forums whose one very active, nobody has happened to understand the problem it as I have seen on this forum…
I ask for your help, you are my last possible assistance else … I will let the module and then I’ll have a wifi module that apparently is easier to implement but I would avoid this solution!
Thank you in advance!
P.S: Sorry for my English must be … huuum … crappy, yes…
I admit I cheat with google translation :3
