I’m using the gEDA PCB program for PCB layouts. My gerber files get split out a bit differently than described on the order page. Specifically, I get the outline in its own separate gerber file. Is that going to be a problem with the Fusion service?
It should be on at least one of the other Gerber files, like the top or bottom copper. It’s mentioned on the web site. The Pulsonix PCB software I use puts it on every Gerber file, by default.
Having the outline on a copper layer might not be the best. A little while ago someone here posting on the forum about his problems getting the files go through the checks at seeed. He only had the outline on one of the copper layers, when changed to a silk layes the files were accepted for production.
