The manual says plug and play, but is there something else I need to do to get the hub to see the sensor?
In the Hub Configuration Tool, I go to Sensor Settings > Builtin > Read.
Then I enable only Sensor Type 2005, then Write.
Then Disconnect, then refresh the SenseCap portal, select the device from the list and it says no sensors.
