my SenseCAP M1 is offline for about 5 weeks. I already restarted the device a few times. The Bluetooth light is not working correctly. Do you guys know what the problem could be?
merhabalar bluetooth ışığının yanmadığını paylaşmışsınız sorunu giderebildinizmi ? Aynı problem benim kullanmış olduğum cihazda’da var eğer sorun ile ilgili bir çözüm bulabidiyseniz paylaşmanızı rica ediyorum
Evet problemi cözüdm. Bana instagramda yaz: yucumb
hocam rica etsem buradan tarif edebilirmisin sorunu nasıl çözdüğünü
I found the solution. You guys can DM me on instagram: yucumb
Hi Yucu,
Unlucky, I’ve got a same issue with my sensecap m1.
Please share your solution how to fix the issue which will help everyone in sense of community.
Many thanks in advance
FYI-The sensecap technical team have resolved my issue.
I have the same problem - who will give me support?
Hi John!
That problem is usually caused by a corrupted micro SD card. If that is the case, you will need to replace it: https://www.sensecapmx.com/docs/sensecap-m1/m1-troubleshooting/#how-to-flash-a-new-image-to-a-new-micro-sd-card
I would highly recommend opening a new ticket here for a personalized support: https://support.sensecapmx.com/ The Sensecap team will be happy to help you ~
