OK, after random changing of USB cords, and re-loading drivers multiple times, I have it showing up on the port…
However, won’t download anything. Keeps generating the following:
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
That’s just trying to load “Blink”.
Not sure what “Programmer” should be set to… On your web pages I’ve seen mentioned “Parallel Programmer”.
I’ve tried 5 or 6 different versions of the Arduino IDE… 1.6.x, 1.8.X. Got to the above with 1.8.X versions…
Tried resetting board multiple times… board LED is flashing (which according to docs means bootloader is loaded…)
Thoughts??
Earl
