I’m looking for some help on what has to be done to make the Canbus shield work with the Seeeduino Lite?
Thanks,
Thomas
Thanks,
Thomas
I believe you will need to use jumper wires to connect SPI of the CAN-Bus shield to the Seeeduino Lite ICSP header as it is basically an Arduino Leonardo clone and SPI pins will not be on Arduino pins 11-13. To clarify, you need to move the MOSI, MISO, and SCK pins. The /SS on pin 10 and /INT on pin 2 should remain connected.
