I accidentally broke the usb-c port on my spartan edge accelerator and was looking for a replacement(320010516 / st-usb-1410) but never found one on mouser, digikey, or lcsc. Any help is appreciated
Some electronics repair shops may carry a variety of USB-C ports or be able to order one for you. Contact local repair shops in your area to see if they can assist you in finding a replacement. Plus, If you are interested to know about how to stops everythings then must explore the provided link.
I would go over to EasyEDA and check out there parts supplier(LSC). They definitely have it.
If you have a BOM or Schematic with the Part no. called out , would also help you locate it on-line
GL
PJ
fyi, I was able to locate the power switch used in the Expansion board with that method(being they are made in china) Exact replacement was possible. ![]()
