I installed a ReSpeaker 4-Mic Linear Array on top of a Raspberry pi zero
I followed these installation steps
</s><i>
</i>sudo apt-get update
sudo apt-get upgrade
git clone https://github.com/respeaker/seeed-voicecard.git
cd seeed-voicecard
sudo ./install.sh
sudo reboot
<e>
Now i have
</s>root@raspberrypi:~# arecord -L
null
Discard all samples (playback) or generate zero samples (capture)
jack
JACK Audio Connection Kit
pulse
PulseAudio Sound Server
default
ac108
dmixer
ac101
usbstream:CARD=ALSA
bcm2835 ALSA
USB Stream Output
sysdefault:CARD=seeed8micvoicec
seeed-8mic-voicecard,
Default Audio Device
dmix:CARD=seeed8micvoicec,DEV=0
Direct sample mixing device
dsnoop:CARD=seeed8micvoicec,DEV=0
Direct sample snooping device
hw:CARD=seeed8micvoicec,DEV=0
Direct hardware device without any conversions
plughw:CARD=seeed8micvoicec,DEV=0
Hardware device with all software conversions
usbstream:CARD=seeed8micvoicec
USB Stream Output
<e>
</s>root@raspberrypi:~# aplay -L
null
jack
pulse
default
ac108
dmixer
ac101
sysdefault:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
dmix:CARD=ALSA,DEV=0
dmix:CARD=ALSA,DEV=1
bcm2835 ALSA, bcm2835 IEC958/HDMI
dsnoop:CARD=ALSA,DEV=0
dsnoop:CARD=ALSA,DEV=1
hw:CARD=ALSA,DEV=0
hw:CARD=ALSA,DEV=1
plughw:CARD=ALSA,DEV=0
plughw:CARD=ALSA,DEV=1
usbstream:CARD=ALSA
bcm2835 ALSA
USB Stream Output
USB Stream Output
<e>
In my application i can set the device to use:
</s>SND_CAPTURE='ALSA: USB PnP Sound Device'
SND_PLAYBACK='ALSA: USB PnP Sound Device'
<e>
What should I write to make my application use the ReSpeaker? ALSA: ???
