ReSpeaker 4-Mic Linear Array Kit for Raspberry Pi - Overflow issue
I am using the ReSpeaker 4-mic linear array with a Raspberry Pi 4.
I made a simple test to capture the data with the PyAudio python library in callback mode, as described below.
Even by doing nothing else on the Raspberry, I receive “overflow” messages.
Does someone already experienced this issue, and know how to solve it ?
Here is my python test script
import time
import pyaudio
import numpy as np
DEVICE_NAME = 'seeed'
SAMPLE_RATE = 48000
N_CHANNELS = 8
FRAMES_PER_BUFFER = 8192
RUN_DURATION = 600 #TEst duration in seconds
def get_device_ind(pyaudio_instance, device_name):
    """Get audio input device by name"""
    for ind in range(pyaudio_instance.get_device_count()):
        if device_name in pyaudio_instance.get_device_info_by_index(ind)['name']:
            return ind
    return -1
def callback(in_data,
             frame_count,
             time_info,
             status_flags):
    if status_flags == 1:
        print('*** pyaudio underflow !')
    if status_flags == 2:
        print('*** pyaudio overflow !')
    # get data in right format
    data = np.fromstring(in_data, dtype=np.int16)
    return (None, 0)
def run():
    pyaudio_instance = pyaudio.PyAudio()
    stream = pyaudio_instance.open(
        SAMPLE_RATE,
        N_CHANNELS,
        pyaudio.paInt16,
        input=True,
        input_device_index=get_device_ind(pyaudio_instance, DEVICE_NAME),
        frames_per_buffer=FRAMES_PER_BUFFER,
        start=False,
        stream_callback=callback)
    stream.start_stream()
    time.sleep(RUN_DURATION)
    stream.stop_stream()
    stream.close()
    pyaudio_instance.terminate()
if __name__ == "__main__":
    run()
