reServer Mod - Added 2nd fan
LOL, Good Stuff dbot :smiley:
, just messing :stuck_out_tongue_winking_eye: with you…
I’ll buy it when I order my Unit. They seem to be a very Solid mini Server . :star_struck:
Hi Bruce!
Can you please share the type, dimension and the connector of the original fan? I want to choose replacement Noctua fan to lower noise level, any recomendations?
Thank you!
There is a conversion cable inside the package, like this:
Attach the datasheet of the fan
316060166-1.zip (3.4 MB)
@dbot Nice design! I can confirm that a fully stocked Reserver definitely needs an exhaust fan. For the moment I rely on a 120x120mm exhaust fan just lying on the top grill and the improvement this makes in temperatures is impressive.
Given that the width of the case is exactly 120mm, is there any reason you didn’t consider fitting a rounded 120x120 fan, like the Noctua NF-A12x25r? That should be more performant (or silent at the same level of airflow) than the thin 92mm fan. If not, any chance you’d be willing to make a modified design? :crossed_fingers:
Though I appreciate Seeed supplying one fan adapter cable, I agree with arcadence that it would be great if we could also buy a second one separately.
What is the 1.25mm connector in the provided fan cable called? I need to get another for my reServer.
For your reference.
https://www.amazon.com/Cermant-Connection-Terminal-Connector-1571-26AWG/dp/B0DFCHWTXK/ref=sr_1_2?crid=1NLXFR7OSU67D&dib=eyJ2IjoiMSJ9.pCljqcIa9A4qeq_azM8P3FZFkyvjnOp3Qbe0BmpCd9SozZ1OkIVbBcRL4Sa0M-IRXyf9kfPcR4c9laCXaB5GexZN3nKz2SJnl-P_AcO_fo-lny9GVnGm__b1n0IO1KzHW8V_r-ON5pbWCmdCXV6xT4BByz8JPsjx4ot7kx92NDxbW9UcMaM6zqwlXnoMSY2Hto7nT8ztVH-55D7sioEaiSpzdNdtVQ3RquQWxjlba8I.b-xtgxC57zqGBTOz5b2DQU73YlAwFQLil2dPAxiZ17Y&dib_tag=se&keywords=JST%2B1.25mm%2B4pin&qid=1751274604&sprefix=jst%2B1.25mm%2B4pin%2Caps%2C294&sr=8-2&th=1
