I am working on a project using a J4011 that requires dual cameras to be used at the same time. I intend to use Gstreamer initially.
I have run into a weird issue: To test the connectivity to the cameras, I run the following command:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM), width=1640, height=1232, framerate=30/1, format=NV12" ! nvvidconv flip-method=2 ! "video/x-raw(memory:NVMM), width=640, height=480" ! nvegltransform ! nveglglessink
The weird thing is that sensor-id=0 correlates with the CAM1 CSI port on the dev board and sensor-id=1 to the CAM0 CSI port.
But the main problem is that it will NOT stream from CAM1 port. CAM0 works fine with either camera.
Terminal feedback from CAM0 that works just fine with either camera attached:
user@jetson-nx:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=1 ! "video/x-raw(memory:NVMM), width=1640, height=1232, framerate=30/1, format=NV12" ! nvvidconv flip-method=2 ! "video/x-raw(memory:NVMM), width=640, height=480" ! nvegltransform ! nveglglessink
Setting pipeline to PAUSED ...
Using winsys: x11
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3280 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3280 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 1
Camera mode = 3
Output Stream W = 1640 H = 1232
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
WARNING: from element /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0: Pipeline construction is invalid, please add queues.
Additional debug info:
gstbasesink.c(1209): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0:
Not enough buffering available for the processing deadline of 0:00:00.015000000, add enough queues to buffer 0:00:00.015000000 additional data. Shortening processing latency to 0:00:00.000000000.
WARNING: from element /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0: A lot of buffers are being dropped.
gstbasesink.c(3003): gst_base_sink_is_too_late (): /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0:
There may be a timestamping problem, or this computer is too slow.
ERROR: from element /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0: Output window was closed
/dvs/git/dirty/git-master_linux/3rdparty/gst/gst-nveglglessink/ext/eglgles/gsteglglessink.c(910): gst_eglglessink_event_thread (): /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0
Execution ended after 0:00:10.248499744
Setting pipeline to NULL ...
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Freeing pipeline ...
Terminal feedback from the not-working CAM1 port:
user@jetson-nx:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM), width=1640, height=1232, framerate=30/1, format=NV12" ! nvvidconv flip-method=2 ! "video/x-raw(memory:NVMM), width=640, height=480" ! nvegltransform ! nveglglessink
Using winsys: x11
Camera index = 0
Camera mode = 3
seconds to Run = 0
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:694 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:247 (propagating)
Got EOS from element "pipeline0".
Execution ended after 0:00:04.036094304
X connection to :0 broken (explicit kill or server shutdown).
(Argus) Error InvalidState: Argus client is exiting with 2 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 366)
WARNING Argus: 6 client objects still exist during shutdown:
281473440514656 (0xffff68000f20)
281473455335360 (0xffff68000cb0)
281473455335520 (0xffff68001130)
281473455335712 (0xffff68001020)
281473455341392 (0xffff68002f80)
281473455349608 (0xffff68003098)
user@jetson-nx:~$
Any help fixing this would be greatly appreciated.
Thanks!
