I have just received my pcbs from Seeed - Thank you for these boards - and I am just having some questions.
The pads on the top layer and bottom layer does not seem to have contact between them. Should there be?
No holes for the components have been done. Should there have been drill holes from manufacturer?
I am only wondering if I have done something wrong when using eagle to produce the design.
Did you enter the schematics in Eagle first and then went over to the layout/board part of Eagle and placed & routed the parts there?
Or did you just “draw” the pads and copper wires directly in the layout/board part?
And did you run the Seeed_Gerber_Generater_v0r95_DrillAlign.cam to generate the Gerbers?
Are all 13 files generated by the .cam included in the zip file you sent to Seeed?
I got a bit anxious about my own PCB order after reading your post, but I finally received the boards today (ordered January 20th) and they seem to be all fine. I had sent the 7 files (G[TB][LSO] + TXT, generated using the Seeed .cam file) in a zip file, sounds pretty much like what you did.
Can you attach the exact file that you sent to Seeed, so that we can check it?
