I recently purchased the Capacitive Soil Moisture Sensor and am using it with my Raspberry Pi.
After connecting the sensor to the Pi’s Grove HAT, it seems to short out the I2C bus completely.
Here is a result from i2cdetect -y 1 prior to plugging in the sensor (note that there are other Grove Connectors plugged in that work at this time):
pi@gardenPi:~/Programming/Python $ i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- 04 -- -- -- -- -- -- -- -- -- -- --
10: 10 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- 44 -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: 60 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Once I plug in the sensor, the I2C bus goes haywire:
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 2f
30: 30 31 32 33 34 35 36 37 38 39 3a 3b 3c 3d 3e 3f
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: 70 71 -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- 1d 1e 1f
20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f
40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f
50: 50 51 52 53 54 55 56 57 58 59 5a 5b 5c 5d 5e 5f
60: 60 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f
70: 70 71 72 73 74 75 76 77
It also appears to short out all the other sensors attached via I2C.
Once unplugging, the bus returns to normal:
I bought 5 of the sensors, and have tested the same results on each one.
Has anyone else run into this issue?
Any help would be appreciated, I’ve been working on this project for quite some time and this has grinded me to a complete stop until I find a solution.
Thank you!
