HI,
I have a raspberry 4 and a base hat.
I want to connect the
- grove buzzer
- grove led
- grove temp hum pro
At each stand i have to connect to the port 12 (pwm). How should this function??? Only one there on the hat…
Thx
HI,
You can connect the grove temp hum, grove led and grove buzzer can also work on general GPIO pins, can you please explain your application.
It’s what i wrote above. a raspberry 4 with a grove hat on it. And a lot of grove sensors.
You can’t use the same pin for other modules if you already used , a better way to use another pin for LED and DHT senor .
