So, the minimum board size is 5cm X 5cm. If my board design is 1cm X 1cm, does that mean that Fusion PCB service will pack my design into the 5cm X 5cm PCB, that is, having 25 pieces of my 1cm X 1cm per 5cm X 5cm panel? Basically, Fusion PCB will make the best use of the 5cm X 5cm PCB panel for my design that is less than 5cm in width an height?
I am not so sure about this PCB service, because the support seems to be very abysmal. They don’t mention to you what needs to be done if they can do your design. Does that mean you lost the payment, etc.?
